Re: checking charging system
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Bob M on April 28, 2000 at 14:48:48 from (171.211.69.235):
In Reply to: checking charging system posted by p on April 28, 2000 at 14:00:48:
Hey p - I just fixed my father in law's '65 Cub Cadet the other nite - had the same problem. Here's what to do: 1 - Start with a fully charged battery. 2 - Stick an accurate voltmeter across the battery terminals. It should read about 12.6 volts. 3 - Start the motor and run at about 1/2 throttle. If the generator and regulator are working right, the voltmeter should read 14.2 to 14.6 volts. 4 - If the meter still reads 12.6, take off the regulator cover and push the upper (cutout) relay closed. If the voltage jumps up to 14.2 - 14.6, the cutout is NG - replace the regulator. If the voltage does not increase, the generator is not working. 5 - If the meter reads somewhere BETWEEN 12.6 and 14.2, the voltage regulator (lower relay in teh regulator) needs adjusting. Gently bend the spring hanger on the relay to stretch the spring while watching the voltmeter. When you get it to about 14.2 volts, stop and replace the cover. 6 - If the above doesn't work, best to simply replace the regulator. I've found they're only good for 2 or 3 seasons - I guess the heat and vibration is hard on them. Good luck!!
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
