Re: supe c clutch housing/place where hydraulics sit???
Posted by ScottyHOMEy on January 07, 2010 at 09:06:14 from (71.241.193.195):
In Reply to: Re: supe c clutch housing/place where hydraulics sit??? posted by riverbend on January 06, 2010 at 20:42:20:
I gotta agree that pics would help. There is a hole about 1-1/2" on the side aout 2/3 of the way back the bell, but its' not threaded. The cap in it is held by spring clips onthe inside - that't the on eRandy refers to for lubig the throwout bearing. On the very underside, only a few inches behind the motor, is an oblong, racetrack-oval-shaped hole (on some tractors it's round, but likely not on a SuperC), that is under the flywheel and clutch. That's for inspection and observing the timing mark on the flywheel, and is usually covered by a n oval cp held in place by a bar, with a threaded studand wingnut.
If you've got something other than those tow. see if you can gt us some pics. I don't know that it would be, but for a SWAG, could you have what was originally a cotton picker that's been turned around to run forward?
