80-90 gear oil is tough to pump, and is going to be difficult to regulate in a wrapped tube on a 1200 degree manifold. I would rather see a coolant line used to heat the differential, but again it is tough to figure out a way to present the heat to the thick oil. in a Hytran filled differential/trans, the oil is much thinner, and would be far easier to run through a oil to water heat exchanger. Some tractors using Hytran fluid as trans lube do not pump the trans fluid through the hydraulics, Those that do tend to have far less problems with water in the fluid, but issues with gear wear particles in the hydraulic oil. Heating it up once or twice a winter seems easiest. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
