Re: Break in oil change
Posted by rustred on January 07, 2010 at 17:04:24 from (142.179.188.160):
In Reply to: Break in oil change posted by deano4863 on January 07, 2010 at 16:43:00:
you could at 50 hrs. but technically you shouldnt have to. is it the same oil you plan on using for its life or is it a lighter oil for wear in? years ago people used to use #20 mineral oil for wear in.myself i like to change oil the first time sooner.every body has ideas but if everything was clean and the oil filter does its job no prob.to run to your reg oil change.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
