Re: 656 3pt lift problem
Posted by TractormanNC on January 08, 2010 at 06:16:28 from (209.42.180.130):
In Reply to: 656 3pt lift problem posted by Steven Kautz on January 08, 2010 at 05:08:07:
Steven, the relief valve Erik is talking about is for the remotes. The hitch relief valve is under the square plate under the seat assembly. The way that hyd system is plumbed up is that the hitch pump adds to the remote/steering pump when the hitch is not in use, but NOT the other way around. The relief valve is factory adjusted at the factory and staked to make it NON adjustable.
Some thoughts
when has the filter and fluid been changed?
worn out hitch pump?
water/ice in the fluid?
3pt linkage adjustment?
