Posted by Steven Kautz on January 08, 2010 at 06:30:15 from (74.33.17.240):
In Reply to: 656 3pt lift problem posted by Steven Kautz on January 08, 2010 at 05:08:07:
Just changed the fluid and main filter, Is there another filter? Had water in fluid and this is just about impossible to get out, added isopropal a couple of times and cracked off water after its had time to set but still a battle. I have the forks mounted directly to the arms with hydraulic top link, don't know how else I could adjust to get better lift? Pump seems pretty quiet and I have a 1000# 3pt counter weight that it lifts no problem. Thanks Steve
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
