Posted by Janicholson on January 08, 2010 at 12:44:47 from (199.17.6.233):
In Reply to: Re: H would not start posted by John T on January 07, 2010 at 13:49:47:
The point at which peak mean effective pressure is achieved in the cylinder depends on four (primary) factors, the speed of the engine, the octane rating of the fuel, the temperature (at the top of the compression stroke in the cylinder), and the compression pressure. These affect the flame propagation rate, and thus the point at which spark based ignition should occur. The near zero RPM of hand cranking, and the resulting modest compression, and ambient temp. usually need a TDC setting for zero chance of kickback. This should be the setting for all ignition systems used on hand cranked engines. It does not drive the total advance, nor does it affect the advance curve. If modern fuel is considered, and RPM is still at 1600 to 2100, total advance must still be in the mid to high 20s. This is due to the relationship between flame propagation rates and RPM. In slow turning, low compression engines, compared to the Automotive engines of today, the advance seems insufficient, but if taken higher it will detonate. Advance should be set to produce the first hint of detonation (knock). At that setting, the Peak pressure is going to arrive near 4 to 6 degrees ATC. This is the sweet spot to gredge power out of the combustion, without driving the rings down around the skirt, or making holes in pistons. I love it!! Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
