Posted by soybeanjoe on January 08, 2010 at 15:15:28 from (66.213.171.108):
In Reply to: Re: Duals on a 1066 posted by blkeele on January 08, 2010 at 14:13:29:
For the "snap-on" type or hub mount duals you don't need a different wheel center. For the hub mount, it just clamps to the axle then you bolt the dual rim to it. On the "snap-on" type duals you remove some of the bolts where the rim claps to the wheel center, put in a different bolt that screws into an "eye". The dual then uses rods with hooks on the end that hook into the eyes. The dual wheel has a "ring" that fits against the regular rim. Rods are thread to tighten the dual against the inner wheel.
Problem with the snap-on type is that there is no gap between the dual & the inner wheel due to the ring. Mud can & will pack in there. Same will happen with a hub mount dual if it's really wet but not as bad or often as the snap-on type dual
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
