Re: Choking my 400 to death
Posted by Bob M on January 08, 2010 at 18:15:37 from (74.74.133.11):
In Reply to: Choking my 400 to death posted by SDE on January 08, 2010 at 17:17:29:
Since your 400 runs fine once started and warmed it suggests a couple possibilities:
1 - The choke plate is not shutting tightly. To check set the choke knob to full, remove the air inlet tube at the carb and peek at the top or bottom the plate, adjust as required so it closes tightly.
2 - New, emissions reformulated (ie crappy) gas. The ethanol, etc. in this stuff makes it less volatile. This in turn makes cold starting (of carbureted engines anyway...) more difficult - especially as the temperature drops. About all you can do there is try another brand of gas, or else simply live with it.
