Re: m sputters and backfires
Posted by James Rumph on January 09, 2010 at 05:02:30 from (24.192.125.175):
In Reply to: m sputters and backfires posted by Justin Hart on January 08, 2010 at 18:34:03:
If the governor is correct ! Did you but one of those cheap TSC rebuild kits ?
Many of us have made this mistake ,those kits are very poor.
I rebuilt a carb on a M and a Cub and they both ran worse after rebuilding them.
The cub would sputter and back fire.
I went to the dealer and spent the money on the factory rebuild kit and they both run perfect.
The after market parts and "O" rings are not the correct sizes so i quessing there was internal leaks and it was sucking air causing a lean condition.
Stick with it there are really nice people on here that will get to the bottom of it.
P.S I have found that the cheap carb cleaner in the can doesn't work like Gumout does, it may cost more but it does work well.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
