Re: M HP with this setup?
Posted by CNKS on January 09, 2010 at 08:55:36 from (216.144.104.128):
In Reply to: M HP with this setup? posted by TedD17 on January 09, 2010 at 08:27:18:
Most HP increase occurs with larger diameter pistons and sleeves, so it depends on what is in the engine at present. The manifold won't add much HP.
