Re: M HP with this setup?
Posted by John A. on January 09, 2010 at 09:55:19 from (76.1.122.170):
In Reply to: M HP with this setup? posted by TedD17 on January 09, 2010 at 08:27:18:
Ted, Also depending on the ammount of slack in the governor. IE pin wear, out of adjustment, will have an effect on the HP too. Just don't assume the governor is in top shape, check it out before to long. 50 is very do able IMO. I went through a 50 model M, put a Super KIt in it a long time ago and didn't throughly check out the governor after the rebuild with simular pistons as you spoke of, I had 42 hp and couldn't get the last 50 RPMs out of the motor.
Later,
John A.
