Posted by Mark in coulterville on January 09, 2010 at 10:44:34 from (99.197.224.57):
In Reply to: Super A block posted by HRed on January 09, 2010 at 08:22:47:
Im not sure that Jb would do the job it might work due to the fact that the cooling system is not pressurized But cast Iron is decieving stuff and the crack might go much further than it appears you should trace the crack and clean all the paint off at least six inches in the direction of the crack Welding would be a better solution However cast iron should be heated to several hundred degrees at the region of the crack in order to burn out any moisture(You will need to drain the block)and a special high nickle rod must be used you can buy these at any welding supply shop you should only need a couple I would try JB first (cheap and easy)Dont forget clean and very dry!! hope this helps! Mark
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
