Re: Want to change brakes on my A
Posted by ScottyHOMEy on January 09, 2010 at 11:22:52 from (70.105.225.9):
In Reply to: Want to change brakes on my A posted by Mark in coulterville on January 09, 2010 at 10:51:13:
No special tools to speak of, but it will take some lifting capacity. On the left side, it's a matter of unhooking the brake linkage, and pulling the final drive away from the transmission. The short diff shaft will comea way with it, and the band will slip right off the drum. On the right side, the brake is on the outer end. That requires a little more creative lifting setup, as the shaft is a lot longer. I THINK you can unbolt just the final, but you'' need room at the side to slip the shaft out of the housing, and you may have a little difficulty lining up the shaft to put things back together. SO, it may be better and in the end and easier to pull the housing first and then slip it off over the shaft. This will involve removing some of the seat platform from eithe the tractor or (easier) from the shaft housing and final drive.
There'd be no better time than while you havte things apart for the brakes to look over the seals around the differential shafts on both sides. There's a seal on each final drive where the shaft passes out through, and another on each side of the tranny. If you've got a lot of oil on the brake drums, take that as a sign of a leaky seal on teh final on the right side. On the left it could be either seal. The only extra work involved, once you're in that far, to change the seals on the final drives is that you'll have to get the brake drums off the shafts, so that you can pull the shafts to replace the seals. Removing the drums will either go easily or require rigging a puller. The seals on the tranny end are pretty straightforward.
