Re: m sputters and backfires
Posted by Red Mist on January 09, 2010 at 18:39:42 from (67.142.130.18):
In Reply to: m sputters and backfires posted by Auzzie Brad on January 08, 2010 at 18:34:03:
Hmmmm! Sometimes runs good; sometimes runs bad. Let me see here.....
1) Check with flashlight for junk in bottom of gas tank at pick-up. May be blocking flow intermittently.
2) Coil beginning to break down?
3) Air leak that developes when something (manifold, carb base) gets hot and expands?
4) Bowl gasket: The two tiny holes in the middle will line up, or not, depending upon orientation of the gasket. Check. You may need to turn the bowl gasket over.
mike
