Re: condensor part#
Posted by TheDurk on January 09, 2010 at 20:56:02 from (71.125.75.218):
In Reply to: condensor part# posted by Harold H on January 09, 2010 at 11:34:43:
Bob said: (quoted from post at 17:23:43 01/09/10) Condensers DO vary in capacity value by application.
The part # I posted is for use with the original coil.
If using another coil, for the best chance of good breaker point life it's a good idea to get a condensor intended for use with the coil you are using.
Everything you said is true. However, that condenser--both the CIH and NAPA versions--is the listed condenser for the IH distributor on 12V C-123 engines as well as 6V. The difference between 6V and 12V does not mean much to a capacitor (very unlike coils). I have been using the IH200 condenser with a NAPA IC13 coil with ICR13 external resistor and, more recently, with the IC14SB coil and no external resistor on my 12V 140. Probably about 20 years on each setup. I believe these are correct combinations and so does my NAPA guy. Are we wrong?
This post was edited by TheDurk at 21:02:24 01/09/10.
