Posted by Erik Dekeyser on January 10, 2010 at 05:41:35 from (76.70.173.93):
In Reply to: Super A pto hp rating posted by Bryan Meade on January 09, 2010 at 21:49:14:
You buy that generator and you will be looking for a bigger tractor. Well that depends it might run the generator but you might not be able to turn on to many things. The generator runs easy with out a load on it. If you want to buy it try it first. If the tractor cant keep 540 rpm it wont put out enough voltage and you can burn out some of the appliances in the house. You have to keep 540 rpm. Good luck Erik.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
