Re: jumping a 6v?
Posted by John T on January 10, 2010 at 06:44:18 from (71.52.15.52):
In Reply to: jumping a 6v? posted by big rich on January 10, 2010 at 04:48:24:
YES its possible and YES Ive seen batteries BLOW UP when its done.
If I just had to jump a 6 volt tractor and didnt have another 6 volt battery to use, I would JUMP THE STARTER ONLY (where possible) to get it to crank and let the in place 6 volt battery power up the ignition as/if needed
Keep polaritys the same !!!!!!!!!!!!!!!
Be careful
John T
