Posted by pete 23 on January 10, 2010 at 10:41:25 from (173.87.15.32):
In Reply to: jumping a 6v? posted by big rich on January 10, 2010 at 04:48:24:
Never connect across the 6 volt battery. If you cannot jump directly to starter with out impressing the 12 volts to the 6 volt battery or components don't do it. It is a rare 6 volt tractor that uses a solenoid operated starter but if it does you would be impressing 12 volts to system by jumping at battery side of solenoid. If you can hook directly to starter you may back feed 12 volts through pull in winding to hold in winding so that is not recommended. You would need to disconnect starter strap from solenoid. Some use a magnetic switch mounted on the starter that is often called a solenoid but is not. You can safely jump direct to starter side on those. Remember, you are relying on the 6 volt battery for ignition unless you have a magneto. Safety first. Sparks will be flying where you make your last cable connection
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
