Re: Frozen Tires
Posted by Nebraska Cowman on January 10, 2010 at 15:38:36 from (66.252.122.171):
In Reply to: Re: Frozen Tires posted by Melvin Ware on January 10, 2010 at 14:43:46:
Yes, If you have reason to believe it's water only DON'T DRIVE IT That would be pretty hard on tires and tubes and likely rupture them. It's like a turkey. It's gonna take a while to thaw. As your tire shop. they should be able to get cloride. It will add likely a hundred pounds per tire. that is one reason it is used. Any salt solution is heavier than water.
