Re: Battery problem.
Posted by rustred on January 10, 2010 at 17:43:50 from (142.179.188.160):
In Reply to: Battery problem. posted by Bradford on January 10, 2010 at 17:03:12:
hard to to figure out which battery your talking about, the new one or old one. but anyway junk the old ones . the new one should crank better than the 2old ones anyhow. yes the cells can short out.the old one will discharge the new one.you dont say what your doin with these batts or what they are for.if you need more cranking power then hook 2 new ones in paralell.you dont say if the old batt. is still hooked up or not.when your getting this spark.also the new batt. may be defective.if your hooking the charger correctly to the new one and it is showing discharge, i would return it.its warranty and let them do the charging and load test.
