Re: Battery problem.
Posted by sflem849 on January 10, 2010 at 18:56:32 from (66.254.196.101):
In Reply to: Battery problem. posted by Bradford on January 10, 2010 at 17:03:12:
I will add one more question, but I have most of the ones above as well. What in the world are you doing!?! Did you have two six volts hooked up in series to make 12 volts and now you hooked up one 12 volt instead? Then you tossed in a 6 volt??? You said pos to pos and neg to neg so I would assume/hope you hooked the new and old 12 volts together???
What tractor? What voltage? What batteries? What???
