Re: Farmall M V8
Posted by glennster on January 11, 2010 at 05:55:34 from (76.217.99.179):
In Reply to: Farmall M V8 posted by Claus on January 10, 2010 at 22:02:43:
the frame rails need to be widened, as the v8 wont fit between the rails. also, you will need to fabricate an engine mounting plate. another area of concern would be the flywheel. depending on how many rpms you are going to run, i dont think the flywheel in the m can handle a whole of them. check down on the pulling forum, chad there seems to be quite knowledgeable in the pullers, i am sure somebody there knows if the mount plates are available or need to be custom made. i 'd ballpark to figure a couple grand to do the conversion with the machining involved.
