Re: Battery problem.
Posted by Red Mist on January 11, 2010 at 10:19:36 from (67.142.130.21):
In Reply to: Battery problem. posted by Tom Fleming on January 10, 2010 at 17:03:12:
sflem849 said: (quoted from post at 19:56:32 01/10/10) I will add one more question, but I have most of the ones above as well. What in the world are you doing!?! Did you have two six volts hooked up in series to make 12 volts and now you hooked up one 12 volt instead? Then you tossed in a 6 volt??? You said pos to pos and neg to neg so I would assume/hope you hooked the new and old 12 volts together???
What tractor? What voltage? What batteries? What???
If I understood him correctly, he had pos to pos and neg to neg, which would mean he had them hooked up in parallel - not series. Therefore, voltage would stay the same as one battery alone. mike
