Dry sleeves can only leak if the block is cracked that the sleeves are in. Head gaskets can leak coolant into oil. Core plugs rusting through can leak. Cracked blocks away from sleeves can leak. Cracked heads can leak. I would pull the pan, pressurize the cooling system to about 6psi max, and look to see where it is coming from. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
