Re: Clutch on a 606
Posted by gqjoe on January 11, 2010 at 17:02:14 from (173.210.195.112):
In Reply to: Re: Clutch on a 606 posted by CNKS on January 08, 2010 at 18:26:01:
Thank-you for the information it is helping alot! I left the washers out between the pressure plate and flywheel and now bolted it in loose so that when i put the motor onto the tractor I have some play with the clutch disc. I was also wondering however, in my manual, the IH 25 one, there is a section about adjusting the release fingers on the pressure plate to a specific height. I was wondering if i do that can I mess that up because there is a black glue on each set screw on the pressure plate? Anyhow thanks again!!
Joe
