Re: three point hitch on super A or Farmall 140
Posted by Red Mist on January 12, 2010 at 05:28:54 from (67.142.130.44):
In Reply to: three point hitch on super A or Farmall 140 posted by mkirsch on January 11, 2010 at 15:13:01:
I install a Worksaver 3-point on my 140 when I am planting. I keep a worksaver 3-point on my Super A to mount a Caroni 5' finish mower. I agree with the others - they are all right. The worst feature about them is the diagonal anti-sway link is cumbersome to disconnect when hooking up or disconnecting from an implement. It needs some sort of quick disconnect feature, which would probably be easy enough to do, (if I ever took the time to do it).
If you get a 3-point for your SA, you will probably want some front wheel weights.
All in all, if you like your SA and you want a 3-point, the Worksaver is probably the way to go - unless you can design and build something better on your own. Hope this helps you.
mike
