Re: H rear wheel casting wobble?
Posted by Armand Tatro on January 12, 2010 at 07:54:01 from (71.201.22.21):
In Reply to: Re: H rear wheel casting wobble? posted by genos on January 12, 2010 at 07:31:15:
How long have you had tractor? Could axle clamps came loose and caused ware to either casting or clamp halves? Remove casting from and check length of bolts and be sure no slop in casting where it mounts to axle. Tighten clamps evenly each one a little at a time. Is the tire itself in good shape? When all is said and done you may still have a little wobble that is impossible to remove. Have you tried switching tires side to side? Do you have another casting, rim, and tire to mount on that side? Armand
