Re: H rear wheel casting wobble?
Posted by Theman on January 12, 2010 at 10:32:10 from (63.107.135.35):
In Reply to: H rear wheel casting wobble? posted by genos on January 11, 2010 at 20:24:19:
A '50 H I bought had the cast key sheared and out of place but still in the slot of the axle. The wheel couldn't seat on the axle shaft correctly and wobbled. If this is the case on your H, you need a new wheel center. The clamp block AND the wheel center both have keys cast in them to locate the wheel properly on the axle.
Now the '51 H I still have had a bent axle. They can be straightened.
