Re: C-123 Camshaft
Posted by El Toro on January 12, 2010 at 14:51:45 from (74.103.74.58):
In Reply to: Re: C-123 Camshaft posted by Thumbtack on January 12, 2010 at 09:36:08:
third party image
I don't think those cam journals wear very easily
and the block bore and journals can be measured for wear. I did a Farmall A back in 1975 & 1976
and it was in sad shape when I purchased it and the 16-inch moldboard plow for $100.00. The engine was stuck, needed fenders, tires, wiring rims and steering wheel. With a complete engine rebuild it ran and looked pretty good. I made the mistake of using our local IH paint. I should've discarded it. I had the clutch disc relined too. Hal
PS: I used the same cam that came in it and it had very good oil pressure. I used 30 wt oil in it.
