Re: 300 U shifting problem
Posted by BMD on January 12, 2010 at 19:49:22 from (65.254.172.6):
In Reply to: Re: 300 U shifting problem posted by 504-2 on January 12, 2010 at 18:43:09:
I suspect the tractor was not used much prior to its sale and it probably has 50+ years of crud and buildup on the rails. Hopefully a good washing down of the rails with PB Blaster will do the trick.
If that fails we"ll drain a couple gallons of gear oil add some kerosene to the rear end and drive around the farm and then change the oil. As for the spring and balls , I plan to remove springs and place tape over the opening to keep the detent balls from escaping. Fishing for springs and balls in bottom of the transmission would be a really bad experience.
Thanks for the info.
BMD
