Re: 656 Fast Hitch problems
Posted by pete 23 on January 12, 2010 at 20:02:29 from (173.87.15.32):
In Reply to: 656 Fast Hitch problems posted by Rick Wuertz on January 12, 2010 at 19:51:25:
Internal leak, probably cyl.Take cover off under seat and observe where oil comes out. There is a drain plug under there to drain that reservoir down to main case, then you can see leak.
