Re: 656 Fast Hitch problems
Posted by IaGary on January 12, 2010 at 20:12:07 from (207.177.17.153):
In Reply to: 656 Fast Hitch problems posted by Rick Wuertz on January 12, 2010 at 19:51:25:
There are very few 20+ year old tractors that the 3 pt or fast hitch will stay up when shut off.
All of my tractors leak down.One is only 8 years old.
The orings inside start to seep a little until constant bouncing in the hitch results when running.
It helps to lower the hitch at each shut off to relieve the strain on the orings before the problem starts.
Mine have never got bad enough to warrant a tear down yet, so I can't help you there.
Gary
