My opinion on this is, Most hydraulic systems in the older tractors have or had water in the oil. When unused for a period of time the water settles in the bottom of the bore of the internal lift cylinder causing rust spots and small pits. When using the 3pt the Orings on the lift piston are scarred by the rust spots and then leak. Usually a hone job and new O rings will help but not completly correct. Isn't there a place on the rear of the 656's you can remove and see the internal cylinder.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
