You won't need a ballast resistor with a true "12 volt" coil.
Suggest you check the spark when the engine is cold. (Pull the wire from the center tower on the disributor, hold it a half inch or so away from the block and crank the engine). You should get a sharp, blue spark.
Then check it again after the engine has warmed up and quit on you.
If now you get only short, lazy yellow spark (or no spark at all...) look for a bad coil or condenser.
But also check the breaker point gap! If the gap's too close (ie. only a few thousanths) it can cause the same symptoms.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
