Re: Remote Hydralics on C
Posted by mkirsch on January 13, 2010 at 09:40:48 from (64.80.108.55):
In Reply to: Remote Hydralics on C posted by mwilke on January 13, 2010 at 07:43:04:
The remote valve pictured in Andrew's bottom picture is a tough part to find. You can get brand new bypass blocks from a vendor on eBay.
Both options will cost about the same overall, because hydraulic spool valves aren't cheap anymore, even from surpluscenter dot com.
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
