Re: distributor
Posted by glennster on January 13, 2010 at 09:57:40 from (76.217.99.179):
In Reply to: Re: distributor posted by Kevin in MI on January 13, 2010 at 09:42:38:
if you have done a distributor on a sb chevy, you shouldnt have a problem. locate tdc on the compression stroke before pulling the mag, make sure the rotor is pointing to #! plug wire in the cap, then you can pull the mag . set up the distributor the same way as far as rotor position and install the distributor. the tractor timing is set with the engine off at tdc,use a test lite and set the distributor so the points just open then lock it down.
