Is it gravity feed from the tank to the injector pump? Sometimes, the lift pump is part of the injector pump, and there is a little lever or plunger to manually pump the fuel. Please note, the manual lever will not work if the pump is on high cam.
Are you getting fuel to the fuel filter from the tank? Check that out too, because you could have ice in the bottom of the fuel tank or the line going to the fuel filter. We always put dry gas (isopropyl) in all fuel tanks in the winter, gas and diesel both. Anti-gel will not get rid of water.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
