Sounds like the idle fuel mix goes lean on long runs. When it happens again try gradually pulling the choke while throttling down. If you find a partial choke setting where it will slow idle OK a lean mixture is the problem.
Possible causes:
1 - Carb idle mix set too lean. Turn the mixture screw IN 1/4 turn at a time to make it richer.
2 - Loose gasket opening up when the engine gets hot allowing a vacuum leak. Check the carb-to-manifold and manifold-to-head gaskets for leaks and the studs & nuts tightness.
2 - Crud floating around in the carb getting sucked into and plugging the idle fuel circuit on long runs. Need to disassemble and thoroughly clean the carb and fuel inlet screen!
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
