Re: 706 farmall hydraulic filter
Posted by Owen Aaland on January 13, 2010 at 13:57:51 from (65.165.246.254):
In Reply to: 706 farmall hydraulic filter posted by gene bender on January 12, 2010 at 20:31:03:
jasonjaberdeen said: (quoted from post at 00:31:03 01/13/10) Help please...
I just changed the hydraulic filter on my 706 and I cant get the loader to work properly.
the power steering, brakes, and TA work ok but not the loader...It does move but it acts like I have air in the system... Any advice?
Did the loader work Okay before you changed the filter?
What are the symptoms you are having that cause you to believe there is air trapped in the loader system? Air in the system should not keep it from lifting but will cause the cylinders to act like they are mounted on springs.
The 706 uses a separate pump for the hitch and auxiliary valves. It is likely that you have a problem in the rear system that still allows the front system to function normally. If you give us a better description of your problems we will be able to suggest some things to look at to discover the problem.
