Re: dry sleeves
Posted by Owen Aaland on January 13, 2010 at 14:11:07 from (65.165.246.254):
In Reply to: dry sleeves posted by oldiron29 on January 13, 2010 at 13:42:52:
Generally use a very light oil, possibly a spray lube or diesel fuel/kerosene.
Most engines if the sleeves can be hand installed 1/3 to 2/3 of the way would be normal.
On engines like the C291, late D282, D361, and D 407 it is critical that the correct amount of force is required to install them because they do not seat in the counter bore. They need to be installed to the proper height and are are held in place by friction only.
