Re: dry sleeves
Posted by Andrew Z on January 13, 2010 at 17:58:42 from (64.252.113.90):
In Reply to: Re: dry sleeves posted by oldiron29 on January 13, 2010 at 17:39:37:
youll have to finish them in with a block of wood and hammer or a press on the top. I have always put them in ice to shrink them down. I looked in a few books that i have and one of them tells the use of a light oil i would use 10w or 20w so that is a method also. i wasnt sure what engine you were working on as some engines use 'loose fit' dry sleeves diffrent game there. If the sleeves do fit too tight though you may have to hone the walls of the block to get them in there. The most important thing is to measure the amout of sleeve above the block hight. You want to make sure that it seats down far enough. They can be flush to .006 above the top of the block. Just make sure the lip on the top of the block is nice and clean and you shouldnt have a problem there.
Andrew
