Re: 656 Fast Hitch problems
Posted by NEKS on January 13, 2010 at 19:52:57 from (76.4.182.153):
In Reply to: 656 Fast Hitch problems posted by Rick Wuertz on January 12, 2010 at 19:51:25:
Just worked on 656 last fall. big 0 ring was starting to come apart on 3 point cylinder after all these years. You get to it like pete 23 said. Took a while to find that drain plug he talked about.
