Re: Remote Hydralics on C
Posted by Randy in NE on January 14, 2010 at 03:55:06 from (204.124.192.31):
In Reply to: Remote Hydralics on C posted by mwilke on January 13, 2010 at 07:43:04:
If you are wanting to lift a wagon box then you will need to add an oil reservoir. The touch control unit only holds 3 quarts. You can plumb it to run two-way cylinders but a one-way will not work without extra capacity. I did this on my C and I have a couple of hundred dollars in all of the hoses, fittings, valve, and reservoir tank.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
