Posted by tackhammertime on January 14, 2010 at 05:17:09 from (65.1.231.9):
In Reply to: hauling my tractor posted by 1940M on January 14, 2010 at 05:01:46:
There is a reason for that hole size has to do with hitch capacity. I had a Mazda B2600I in the 90's a freind told me I had twice the truck as his 4000, and could not tow much because of the truck tow limits. I wouln't put an M with trailer behind a Mazda Truck if you value your truck and tractor.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
