Posted by 1940M on January 14, 2010 at 08:09:55 from (64.33.132.10):
In Reply to: hauling my tractor posted by 1940M on January 14, 2010 at 05:01:46:
I would think my truck can handle it if I'm careful. I've pulled loaded gravity wagons in from the field with it with no problems. They must wiegh as much as my M does? Dad won't let me use his truck anymore. So that's out of the question.
I asked dad and he said the trilaer has 2, 3500lbs axles under it and he's hauled his 560 with it behind his 1/2 ton so my Madza should handle an M just fine if I'm careful.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
