Posted by MeanGene1 on January 14, 2010 at 08:26:49 from (204.14.185.33):
In Reply to: hauling my tractor posted by 1940M on January 14, 2010 at 05:01:46:
You're not listening, and you're sure not getting it- your truck is way too small to safely tow an M- period. You need to understand that there's a lot more to towing than being able to get the trailer moving- you need enough weight and brakes to control it. Moving stuff around on the farm is a lot different than down the highway at speed- and you need to consider the other folks on the road. You will NOT be able to stop that combination quickly and /or safely with a little Mazda- the trailer & load weight will take you for a ride Just a bad idea- please listen to folks with a lot more experience than you, that little truck just isn't a big towing vehicle
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
