Posted by Paul Shuler on January 14, 2010 at 09:28:52 from (170.29.248.3):
In Reply to: hauling my tractor posted by 1940M on January 14, 2010 at 05:01:46:
U need at the least a 3/4 ton truck and the trailer may even be a bit light. I pulled an h on a 16' trailer with 3600 lb axles and it was all it wanted. I upgrade to an 18' with 7000 lb alxes and I'm much happier. The truck. NO WAY! I wouldn't pull it in the yard with a small little truck like that. You will have very poor results if you live through it.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
