Re: hauling my tractor
Posted by mkirsch on January 14, 2010 at 09:37:17 from (64.80.108.55):
In Reply to: hauling my tractor posted by Mike(NC) on January 14, 2010 at 05:01:46:
1940M said: (quoted from post at 09:09:55 01/14/10) I would think my truck can handle it if I'm careful. I've pulled loaded gravity wagons in from the field with it with no problems. They must wiegh as much as my M does? Dad won't let me use his truck anymore. So that's out of the question.
I asked dad and he said the trilaer has 2, 3500lbs axles under it and he's hauled his 560 with it behind his 1/2 ton so my Madza should handle an M just fine if I'm careful.
No. No. No. No. No.
Hauling a gravity wagon at 15MPH down the road for a few miles is way different than hauling 8000lbs hundreds of miles at 65MPH.
The trailer is not heavy enough to handle the M, period. He seriously stressed it out with the 560. I wouldn't trust it to haul a garden tractor at this point.
Truck manufacturers exaggerate towing capacities as it is. You are trying to haul way more than even the manufacturer says you should haul.
