Posted by mkirsch on January 14, 2010 at 09:40:23 from (64.80.108.55):
In Reply to: hauling my tractor posted by 1940M on January 14, 2010 at 05:01:46:
The problem here is that you're using the logic: 3500 + 3500 = 7000, therefore I can put 7000lbs on the trailer.
Wrong.
Trailers rate their capacity based on TOTAL weight, not the weight of what you put on them. A 7000lb trailer is rated to WEIGH 7000lbs, not to haul 7000lbs.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
